fosgate3
Mar 08, 2021Tutor
EX7000 ... probably a simple question here
This will probably be a very easy question for someone to answer. I bought an EX7000 AC1900 originally to use as a range extender but ended up not needing it for my original plan. Can it be used as a...
Mar 08, 2021Guru - Experienced User
Not as a router but you can hardwire it into the wndr3400 and run the ex7000 in access point mode.
Then you could either use the wndr3400 as a backup wireless, as a way or reducing the load on the network, or even just disable its wireless.
- fosgate3Mar 09, 2021Tutor
And I would do that just by connecting an ethernet cable from the 3400 to the 7000 and then using the "extended signal" produced by the 7000 to connect to, right?
- plemansMar 09, 2021Guru - Experienced User
There's an install article on it.
https://kb.netgear.com/26078/Install-the-EX7000-as-an-Access-Point
Thanks so much!
