fosgate3
Mar 08, 2021Tutor
EX7000 ... probably a simple question here
This will probably be a very easy question for someone to answer. I bought an EX7000 AC1900 originally to use as a range extender but ended up not needing it for my original plan. Can it be used as a...
fosgate3
Mar 09, 2021Tutor
And I would do that just by connecting an ethernet cable from the 3400 to the 7000 and then using the "extended signal" produced by the 7000 to connect to, right?
Mar 09, 2021Guru - Experienced User
There's an install article on it.
https://kb.netgear.com/26078/Install-the-EX7000-as-an-Access-Point
- fosgate3Mar 09, 2021Tutor
Thanks so much!
