DrCyKosis
Mar 06, 2021Aspirant
EX7000 Quits Serving Up IP Addresses
Todays Netgear is not what it used to be...and support is CRAP! I have an EX7000 Extender. At some point, the connected devices still communicate to the router, but it won't serve up IP adresses...
DrCyKosis
Mar 08, 2021Aspirant
Thanks! Yes I did...didn't make a difference.
What really is odd..
.the connected devices still work...it just won't obtain a new ip address. Not sure how the internals work, but it defies logic.
DrCyKosis
Addendum: One other thing...I can walk over to the router, and obtain an IP address on 2.4ghz and 5ghz. Yet, go back by the range extender, and it authenticates, but hangs on "obtaining IP address".
Thanks!
Thanks!
- plemansMar 08, 2021Guru - Experienced User
Have you tried using it without the one wifi feature enabled?
