lostinqueens's avatar
lostinqueens
EX7000 Range Extender Blocking an IP Address
Greetings, I have a Netgear EX7000 wifi range extender that has worked well for several years. Lately, one of the ip addresses connected to the EX7000 is not reachable when connecting from our main ...
  • plemans's avatar
    Dec 14, 2021
    What firmware version are you on? I've seen a few people with issues on the latest firmware.
    Maybe yours updated and its causing issues.
    A couple things you can try.
    1. try a factory reset. Sometimes after a firmware upgrade, old settings can cause issues. Try factory resetting and reinstalling.
    2. try downgrading the firmware. If it is indeed the firmware, a downgrade should fix it.
