spricevancouver
Jun 20, 2022Aspirant
ex7000 sets up but won't recognize password
i upgraded my modem/wifi box and tried multiple times to reinstall, reset the extender , the install seems to work but when i try the 2g or the 5g band it won't accept the password, i left the passwo...
Jun 20, 2022Guru - Experienced User
Are you installing with wps or using the installation assistant?
What router are you connecting it to?
Are you using any special characters or spaces in the ssid/password?
- spricevancouverJun 20, 2022AspirantInstalled with the install genie, and no special characters in the password and I am using the new share fiber gateway2.0
- plemansJun 21, 2022Guru - Experienced User
What actual model gateway is it? (look on the label)
- spricevancouverJun 22, 2022Aspirant
Shaw fiber gateway 2.0
CM MAC: C09435EAA485
MTA MAC: C09435EAA486
Model: TG4482
FCC ID: UIDTG4482
IC: 6670A-TG4482
CAN ICES-3(B)/NMB-3(B)
Input/Entrée: 12.0V === 4.6A
