schumaku
Sep 29, 2018Guru - Experienced User
EX7000 V1.0.1.78_1.0.140 Update Observations: Smart Connect Oddities, Release Notes
Long-term operating EX7000, operating in Access Point Mode (with anEthernet uplink), updated from 1.0.0.32 to V1.0.1.78_1.0.140 (flawless that far).
One new feature seems to be Smart Connect, i...
Murfinva
Oct 02, 2018Aspirant
Updated to latest Firmware 1.0.0.158 , connection dropped from 433mbps to 90 mbps (I Have a 1GB Dual band Netgear router). Tried 1.0.0.148 same thing, went back to 1.0.0.136 now back to the 433mbps. What a waste of time. Read all the release notes, folowed the instructions. DOES NOT WORK.....
schumaku
Oct 03, 2018Guru - Experienced User
That's not an EX7000 unless I'm very wrong. The issue the more and more users are expereincing on EX7000 V1.0.1.78_1.0.140 are different. You might want to open a dedicated thread on the EX7700 (wild guess) issue please.
- schumakuOct 03, 2018Guru - Experienced User
Christian_R ChristineT - it can't be that enabling Smart Connect (adding 802.11k) does require the EX7000 configured to AP mode connected (wireless???) to another wireless. Leaving alone the many problems uses are experiencing with this "update", please send this firmware back rejected - and don't forget the one way ticket for QA to Tasmania.
What concerns me is that nobody from Netgear - I don't talk of ChristineT, she has different responsability and job - does manage in time to follow up the exploding number of EX7000 trouble reports.- Christian_ROct 03, 2018NETGEAR Employee Retired
schumaku - Thank you for the feedback on the recent firmware for the EX7000. We would like for support to follow up on the issue. If so, please PM with your contact info.
~Christian
Done. Curious on how support can help about implementation/design oddities (where the EX7000 in wired AP mode does request to connect to a wireless on enabling Smart Connect to gain 802.11k capabilities).
- MurfinvaOct 03, 2018AspirantAnd although not the same issue the .140 update does not work, not only my signal dropped but would not stay connected.
I do have:
Netgear Nighthawk Wi-Fi Range Extender AC1900 Dual Band Gigabit (EX7000-100NAS)
As I read here Netgear has not fixed the update and apparantly will not fix it.
