schumaku
Sep 29, 2018Guru - Experienced User
EX7000 V1.0.1.78_1.0.140 Update Observations: Smart Connect Oddities, Release Notes
Long-term operating EX7000, operating in Access Point Mode (with anEthernet uplink), updated from 1.0.0.32 to V1.0.1.78_1.0.140 (flawless that far).
One new feature seems to be Smart Connect, i...
schumaku
Oct 04, 2018Guru - Experienced User
Retired_Member wrote:
I've just disabled the "Smart Connect" feature
Curious how you had it enabled - we are promped to connect to a wireless, and there we stopped the process (as using a LAN connection of course)?
(which I can't see how this would be relevant in AP mode anyway...)
Smart Connect does balances your the WiFi connections to the router/AP on two or more radio bands. Your router uses Smart Connect to choose the best radio band for your device to give you the best WiFi performance. For Smart Connect to work, all radios invovled must use the same WiFi network name (SSID) and network key (password).
Anonymous
Oct 04, 2018OK, I realise my comment about Smart Connect might be ill-informed... anyway, seems much more stable since disabling it.
I'll post back if I get more problems.
Oh, and NETGEAR, if you're listening: the pop-up window every time I login to the EX7000 web UI is super-annoying!!
- AnonymousOct 05, 2018
My EX7000 is still having problems, I'm reverting to firmware V1.0.0.66_1.0.126.
- ltoons1462Oct 22, 2018Tutor
I had to revert to 1.0.0.66 as well. The 1.0.1.78 firmware rendered both of my EX7000s useless. Nothing could obtain an IP Address.
The lack of Netgear's response to all these issues is deafening. Seems rediculous to spend $89 for support on a problem THEY INTRODUCED! I'm sure we would all like to help them resolve the issue IF SOMEBODY WOULD JUST WORK WITH US HERE!
