BooYah
Dec 03, 2024Tutor
EX7000 wifi extender - I need to keep rebooting device.
I need to keep rebooting my device to make it work. All devices lose connection as device does not recognize password. After reboot the device will work for about a day then devices lose connection...
Dec 14, 2024Guru - Experienced User
Just set it up in the default mode.
Or if you're using fastlane, you can set the 5ghz to be the connection between router/extender.
BooYah
Dec 14, 2024Tutor
Just so I understand. The EX7000 will extend the three band XB8 WiFi 6 signal and the EX7000 can be split the incoming three band signal into a separate 2.4ghz. Is this a correct understanding?
- plemansDec 16, 2024Guru - Experienced User
The EX7000 isn't triband (or 6ghz at all).
So it won't pickup the XB8's 6ghz band.
It will pickup the 2.4ghz/5ghz and rebroadcast those just fine.
- BooYahDec 16, 2024TutorIf the signal is sent as a combined single band can the EX7000 split and retransmit the 2.4ghz and 5ghz into separate bands with unique and nameable SSIDs
yes it can. Just use the installation assistant for setup and not wps.
- BooYahDec 16, 2024TutorWhat is the URL (location) for the installation assistant?
- plemansDec 17, 2024Guru - Experienced User
here's a video of using it.
