jwgarner71
May 22, 2020Tutor
EX7000 WIFI issues
I am having issues with the WIFI for my EX7000 ranger extender. The WIFI shows online for both 2.4/5 bands, and my devices are connected, but I receive an error that there is no internet connection. ...
- May 22, 2020
I would actually look at the router first. The R7000 isn't known to have great firmware and when you're running an extender, the router is the key point.
Try installing firmware version 1.0.9.42 to the R7000. Factory reset it afterwards, and then manually re-setup the router. Disable autoupdates.
Try that first.
What modem are you using?
May 22, 2020Guru - Experienced User
Try that first.
- jwgarner71May 22, 2020Tutor
I will the firmware fix and reply back here.
My ISP is MetroNet, so it is a fiber connection using a AdTran 411 terminal.
- jwgarner71May 24, 2020Tutor
I reverted the firmware and the issue is still there. Doesn't appear to have made a difference is the frequency of the drops at all, I'm afraid.
- plemansMay 24, 2020Guru - Experienced User
Did you reset the r7000 after the downgrade and manually reinstall it?
Yes, I did manually reset after the firmware download, as well as reset the extender.
