davidgsmith1
Aug 22, 2024Tutor
EX7000 Wired to router
Hello, is it possible to connect the extender to the router by ethernet to extend the signal, rather than wifi?
- Aug 22, 2024
davidgsmith1 wrote:
I just found out that the EX7000 does not support Access point. I need to buy another extender
Who told you that?
there's a few low end models that don't support AP mode but I haven't found any of the higher ones that don't.
And we're talking really low end like the EX2700.
I've got a EX8000 and an EX7300 and both support AP mode. I don't specifically have an EX7000 but even the manual (page 18) says it supports access point mode.
https://www.downloads.netgear.com/files/GDC/EX7000/EX7000_UM_EN.pdf
Aug 22, 2024Guru - Experienced User
Yes, just put the EX7000 in access point mode
- davidgsmith1Aug 22, 2024Tutor
Thank you. would you be able to tell me how to do this please?
I have been a call to their call centre in India for over an hour and am no further forward - just going round in circles, and I don't know any more than I did before I called them !!!
- plemansAug 22, 2024Guru - Experienced User
Here's the guide
https://kb.netgear.com/000060286/How-do-I-install-my-NETGEAR-WiFi-range-extender-as-an-access-point
and a video of it
https://www.youtube.com/watch?v=xaYDUw5Vg7s
Thank you I notice this is for EX6120, is it the same for an EX7000?
