davidgsmith1
Aug 22, 2024Tutor
EX7000 Wired to router
Hello, is it possible to connect the extender to the router by ethernet to extend the signal, rather than wifi?
- Aug 22, 2024
davidgsmith1 wrote:
I just found out that the EX7000 does not support Access point. I need to buy another extender
Who told you that?
there's a few low end models that don't support AP mode but I haven't found any of the higher ones that don't.
And we're talking really low end like the EX2700.
I've got a EX8000 and an EX7300 and both support AP mode. I don't specifically have an EX7000 but even the manual (page 18) says it supports access point mode.
https://www.downloads.netgear.com/files/GDC/EX7000/EX7000_UM_EN.pdf
Aug 22, 2024Guru - Experienced User
Yes, just put the EX7000 in access point mode
davidgsmith1
Aug 22, 2024Tutor
Thank you. would you be able to tell me how to do this please?
I have been a call to their call centre in India for over an hour and am no further forward - just going round in circles, and I don't know any more than I did before I called them !!!
- plemansAug 22, 2024Guru - Experienced User
Here's the guide
https://kb.netgear.com/000060286/How-do-I-install-my-NETGEAR-WiFi-range-extender-as-an-access-point
and a video of it
https://www.youtube.com/watch?v=xaYDUw5Vg7s
- davidgsmith1Aug 22, 2024Tutor
Thank you I notice this is for EX6120, is it the same for an EX7000?
should be pretty much the same.
they all uses pretty similar install processes. The difference tends to be if it has a hardware switch for access point mode or extender mode
