declanb's avatar
declanb
Follower
Nov 03, 2015
EX7000 with USB 3.0 Hub
The EX7000 (Extender/Access Point) has one USB 3.0 port. Can I use the ReadyShare facility with a USB drive and a USB printer simultaneously by connecting a USB 3.0 hub to the EX7000?
  • nhann's avatar
    Nov 04, 2015
    Hi declanb,
    Unfortunately, the EX7000 will not work with a USB3.0 Hub as you described.
    It is possible to use the hub with only harddrives. But the USB printer will not work with the hub.
