Lindasmo
Jan 10, 2020Initiate
EX7300 - all lights on, but not connecting
I've been using this extender for about 6 months with no real issues. All of a sudden it's not connecting, despite all the green lights on. The router is working, and has been unplugged and plugged b...
- Jan 17, 2020
HI Lindasmo,
Welcome to the community! May you try pressing down on the factory reset button for 30+ seconds and running through the setup assistant again. You may also try running through the setup with the extender wired via ethernet port to the router. Please let me know if your issue persists.
Christian
Christian_R
Jan 17, 2020NETGEAR Employee Retired
HI Lindasmo,
Christian
- LindasmoFeb 04, 2020Initiate
Hi Christian, that did the trick, and I was able to update the firmware.
Thank you!
