coleman10
Apr 04, 2017Tutor
EX7300 - Data lag
Hi. I just got an EX7300 last night and the setup went well. I've been experiencing an issue with connectivity, however. When I connect a wifi device (in this case, an iphone) to either of the ...
- Apr 22, 2017
And here's the fix. Set the HTTP Proxy setting to Auto, leave the URL value blank. I have no idea why this works, but I've tested it a few times and there is no longer a lag or failture in getting through the extender.
DarrenM
Apr 06, 2017Sr. NETGEAR Moderator
Hello coleman10
What kind of speed are you getting on the extender network.
DarrenM
- coleman10Apr 07, 2017Tutor
Hey, DarrenM.
The connection to the existing bands are: 2G - 115Mbps, 5G - 701Mbps. Signal strengh is great between the gateway and the extender.
I just connected to the 2G extension from my desktop machine and the speed shows as 144Mbps.
Just found this thread: https://community.netgear.com/t5/WiFi-Range-Extenders-Repeaters/Netgear-Wifi-booster-and-iPhone-hate-each-other/td-p/1222838
I don't have the bands bridged, but I'm experiencing the same problem. I'm not sure if this guy ever found a fix, but it appears that iphones just don't want to work with Netgear extenders.
Thanks.
- coleman10Apr 22, 2017Tutor
