fatburger1849
Apr 24, 2024Initiate
EX7300 - do firmware updates have to be applied sequentially
Do the firmware updates have to be applied sequentially? There are a LOT of them since the version I have including some that seem to relate to upgrading to a mesh network. Given that the size of eac...
fatburger1849
Answered my own question. They're cumulative - I went directly from version
V1.0.1.60 to version V1.0.2.164 and it works fine.
Apr 25, 2024Guru - Experienced User
Glad it worked for you!
There's a few routers that need a stepped approach if the firmware expands the provisioning. Much less likely on an extender.
But I'd mark yours as solved so others aren't still trying to fix it 🙂 good work
