arnostko
Feb 27, 2019Aspirant
EX7300 and "positive" MAC address filtering
Hi all,
I just bought and set up the EX7300 and was shocked to find out that it can't filter MAC addresses based on a list of allowed devices. This is the case on my router (WNDR3700) and also ...
- Feb 28, 2019
Hello arnostko - You may refer to the to the article link below for MAC filtering on the extender
~Christian
Christian_R
Feb 28, 2019NETGEAR Employee Retired
~Christian
- arnostkoMar 01, 2019Aspirant
Thanks Christian,
so if I understood this correctly, the router should do the MAC address filtering centrally. Which makes sense: you only need one list of allowed devices. Unfortunately my old router (WNDR3700) does not filter over LAN, only via wireless. So an upgrade of the router is needed.
I would still expect for older routers like mine to be able to configure the AP manually :(
