DanDVA
Jan 15, 2020Aspirant
EX7300 can't connect to admin page
This thing works fine, unless I have to change something. Recently changed my router, so needed to re-do setup on the range extender. I was only able to access the admin page via the IP address, 19...
- Jan 17, 2020
Hey thanks S for the reply. I'm sure you can tell I'm frustrated.
I'm not sure I buy your explanation. The extender will get an IP on the "router side" from the router, yes. But it doles out its own IPs on the "extender" side network. The router doesn't have to "forward on" traffic to mywifiext.n*t, because that traffic doesn't get to the router without going through the extender first, which is supposed to detect it and show the admin page.
My "router" is an iPhone 6 running as a hotspot. Now before you shake your head and blame that screwy setup (it's the best Internet I can get here in the sticks), it's been running fine that way for literally years on an iPhone 5c. I upgraded my main cell phone from the 6 and pressed the 6 into Internet gateway duty.
I don't believe there is any way to see precisely what devices are connected to an iPhone, only the quantity of connected devices. So that's no help.
Last night I took another crack at it. Powered off the extender, turned off wifi on the PC and turned it off. Powered up the extender, waited for it to boot. It connected to the iPhone hotspot. Connected a cable from the PC to the extender Ethernet port, and turned on the PC. Then I went to the kitchen and poured myself a beer to give everything some time to get composed.
When I got back, I opened Chrome and had no problem connecting to the admin page, updating firmware, and completing the configuration. I connected via mywifiext.n*t, but could see it was using the default 192.168.1.250 IP address. This is a different range from that assigned to the router by the iPhone.
In any case it's done, and this PC is now on WiFi to the extender, which is connected to the iPhone 6 and from there the Internet.
BUT - when I'm on WiFi I can't get back to the extender admin page. Luckily I don't expect to have to very often, and when I do I can use the trick with the cable. Therefore I still maintain that the extender software is crap. Netgear should either make it work reliably over WiFi, or eliminate that feature and require a cabled connection for admin. Or at least document some additional solutions like the one that worked for me. None of these scenarios seem likely though.
DanDVA
Jan 17, 2020Aspirant
Jan 17, 2020Guru - Experienced User
The phone "router" is still controlling dhcp.
