bl1085
Jul 28, 2019Guide
EX7300 extender - cannot connect to existing 5G network
Hello Been fighting this for several hours with no progress. I have an ORBI RBR50 which works well. I have it set to 192.168.2.1. I turned off access control for the purposes of this conn...
bl1085
Jul 29, 2019Guide
OK - my hunch worked - I downgraded to firmware version 72, and now it is working.
not sure exactly what my next steps will be, but probably just sit for a few months and see if Netgear figures out the latest firmware has issues, then if they publish something higher than 140 I might give it a try.
dtdfusion
Aug 04, 2019Aspirant
I thought it was just me. i upgraded orbi to V2.3.5.30 last night and now my ex7300 couldn't connec to orbit router whereas my other netgear extender connecting fine.
- bl1085Aug 04, 2019GuideInteresting to hear others are having the same problem. I resolved it by downgrading the EX7300 firmware rather than the ORBI firmware. Interested to hear if downgrading the ORBI firmware is an alternate solution.
- dtdfusionAug 04, 2019Aspirant
i rolled back the orbi firmware to 2.2.1.212 and everything works like before until orbi auto update to newest firmware again and ex7300 stopped connecting right away. i guess i will roll back the ex7300 firmware as temporary measure.
i stand corrected on the auto update of orbi. after i rolled back to previous version of on orbi router/satellites, the ex7300 works again and everything as before. in conclusion, V2.3.5.30 does not work with ex7300 V1.0.2.140
