KaiBarb
Mar 31, 2021Follower
EX7300 is not broadcasting NETGEAR_EXT
I'm trying to setup this extender. The extender is not broadcasting, per this instruction: "To connect with WiFi, on your WiFi-enabled device, open the WiFi connection manager and locate and con...
Mar 31, 2021Guru - Experienced User
did you already try setting it up using wps?
What many don't understand is that its a mesh extender and when you set it up using wps, it by default uses the same ssid as the router. So it doesn't show up seperate.
I've seen several people try setting up using wps and not think its working because it doesn't show as seperate.
You could also try hardwiring a pc/laptop into it and connecting to it that router to see if its already setup.
