apil1
Sep 23, 2018Apprentice
EX7300 Mesh with OneName and FastLane hidden network for backhaul
Looking to see if my specific setup is going to be technically supported. I have an R8000 router on the second floor and an EX7300 for the first floor I've been using in standard extender mode using FastLane to connect the 5GHz channel to the router. I'd like to add an EX7500 to the first floor and move the EX7300 to the basement and switch it to mesh. I was thinking I would disable Smart Connect on the router and use the 2nd 5GHz channel as a hidden network for the backhaul. I wanted to see if mesh would be able to support OneName and FastLane using this method.
- apil1Apprentice
I was trying to get an idea if OneName worked in conjunction with FastLane being enabled and trying to manually configure the backhaul using a hidden WiFi network. I went ahead and reset the configuration on the EX7300 and when FastLane was enabled OneName was not an available option. I had set up OneName using the setup wizard first and then kept the same network settings after enabling FastLane where the EX7300 is manually configured to join the 5GHz hidden network for the backhaul and the 2GHz SSID and channel are the same as on the router. It seems to be functional but was not sure if OneName was supported in conjunction with FastLane. If I have to manually configure the network to be similar to OneName do I choose the same SSID and channel as the router or same SSID and different channel?
