bacincny
Mar 23, 2020Aspirant
EX7300 no internet
Hi, Installed the EX7300v2 several times, using both WPS and Network Setup, factory reset between tries. Connects to my router fine, both 2.4Ghz and 5Ghz. But, when I connect a device to the exten...
Mar 23, 2020Guru - Experienced User
if you look up that router, you're not the only one having issues adding an extender to it.
tp-link/netgear all have had issues connection. I haven't seen any solutions to it.
