Tomcatpooh24
Jan 07, 2021Aspirant
EX7300 On Light working only
I am running Windows 10 Pro ver 20H2. My router is the Nighthawk AX12 (RAX120). I am using the Netgear extender EX7300. I attempted to update the extender with the latest firmware after receiving ...
Jan 07, 2021Guru - Experienced User
you can try recoving it via tftp.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
Tomcatpooh24
I plug an ethernet cable from my desktop to my extender EX7300 and I followed the guideline for the tftp firmware upload twice with no success. The video shows the guy downloading tftp2.exe. I am not sure where he got that from. I followed the guidelines to activate windows 10 tftp before trying to flash the extender. It still did not work. The second suggestion is a few levels over my head.
nmrpflash. I wasn't sure which of the nmrpflash I should use or how to use it. for example: nmrpflash.dev, nmrpflash.manifest, and nmrpflash.rc.. If possible would you explain a little simpler. Thanks
