Tymok
Apr 03, 2021Aspirant
Ex7300 or ex7500 as an orbi extender
My orbi RBW30 satellite broke down and I'll be replacing it with an extender. what would be better, to get a ex7300 and connecting it to my orbi with an Ethernet cable or a ex7500 and connecting it ...
- Apr 04, 2021
You'll get better performance out of the ex7500 versus the ex7300 because of the dedicated backhaul. That's the route I'd do.
Apr 04, 2021Guru - Experienced User
Is there a reason you're not buying an orbi satellite?
the following are compatible so you can use the backhaul link:
rbs20
rbw30
rbs40
rbs40v (tends to go on sale a lot on amazon)
rbs50
rbs50y (outdoor version)
- TymokApr 04, 2021AspirantId prefer a wallplug. I’ve got a plug just under the sealing, no shelf’s, no wall-mount’s etc.
Just a plug and a Ethernet cable.
In my country used Orbi satellites aren’t available. I can get a new RBS40v and RBS50.
They cost ca. 290 and 330 USD (vat incl.)
I can get a used ex7500 for 70 USD and a ex7300 for 90 USD.
I was considering an AP. The solution has to be cheap. It’s only for one printer and an outdoor camera.- plemansApr 04, 2021Guru - Experienced User
