Emeryw25
May 08, 2020Aspirant
EX7300 problem setting up after firmware update
I recived my new Netgear Nighthawk AC220 EX7300v2 today. I did the setup with the app, took longer time for the app to find the extender, It told me to go to Wifi settings to connect with Netgear_EXT...
May 08, 2020Guru - Experienced User
If it setup in default mode, it sets up with mesh/single ssid enabled. Meaning it connects to the router and uses the same ssid.
It can be confusing at times.
What you can do for ease of setup and to be sure its setup how you'd like?
Factory reset the extender, push and hold reset for 7-15 seconds while powered on.
Then hardwire in the extender via pc/laptop. Make sure that device has its wifi off so it doesn't default back to the wireless.
Then go through setup via the hardwired in device.
Setup this route tends to go smoother and faster and you can be sure everything is setup and working how you want.
Emeryw25
May 15, 2020Aspirant
Thank you plemans for helping me.
Should I get a Wifi 6 Extender? Seems like when you go to something newer that came out, something else new comes along.
- plemansMay 16, 2020Guru - Experienced User
Your bottleneck is the dsl. You can have the worlds fastest extender but it isn't going to be faster than your dsl setup.
