gilrami2's avatar
gilrami2
Follower
Jan 23, 2024
ex7300 reset can't connect to admin page or app
I have a older ex3700 extender, I keep using it from time to time as need, it has always worked.  I reset it and assigned it's own ssid for 2.4 and 5 but I can't see it on the router to get ip address and I can't log into any admin page using browser or the nighthawk app. My ultimate goal is to try and update firmware to see if it will convert to mesh so I can use with other mesh network.  Can anyone help with how to log into the extender and then update firmware?
Thanks
1 Reply
  • plemans's avatar
    What I'd do?
    1. download the firmware version for it from other netgear site.
    2. factory reset the extender. Push and hold reset for 7-15 seconds while powered on
    3. use the installation assistant to set it up. It can be setup with mesh or separate ssid this router. Or even AP mode.
    4. you can update the firmware after installation. Not hard to do.
    Here's a video of how to use the assistant.
    https://www.youtube.com/watch?v=yJVklshxBMk
