Dantecat
Sep 08, 2016Follower
ex7300 router to extender connect
This extender is working well, but I am wondering what is best configuration to use, what are the pros/cons, of router:extender and extender:client. Use both 2.4 and 5 Ghz for both: Use 2.4 from rout...
DarrenM
Sep 09, 2016Sr. NETGEAR Moderator
Hello Dantecat
That just all depends on the environment you are using it in you would have to experiment to find what works best for you.
DarrenM
