Numismad
Jun 12, 2023Aspirant
ex7300v2 cannot extend signal from Linksys EA9500V1
Hello everyone! router Linksys EA9500V1 2 wireless 2,4GHz and 5GHz Security mode: WPA2 Personal from: WPA2/WPA Mixed Personal WPA2 Enterprise WPA2/WPA Mixed Enterprise WEP I am tr...
Jun 12, 2023Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Numismad
Hi Plemans! Thank you for your attention,
Yes I tried to use installation assistant
but nothing, sometimes it's brought me only connection 5GHz
Lynksys don't have WPS button, but I made experiment.
I have another router - D-link Archer AX50 with WPS
and after "Your extender has successfully connected to your existing WiFi network." (look screenshot pls)
its brought ONLY 5GHz connection but 2.4 - not working....
I think probably it's problem with firmware of ex7300v2? (
Any ideas?
Thanks!
- plemansJun 16, 2023Guru - Experienced User
Your photo shows both connected.
What firmware are you on for it?
- NumismadJun 16, 2023Aspirant
Thank you for your answer.
yes it shows like connected but after it is not connected
I try to use any firmware, last one EX7300v2_EX6400v2_EX6250v1_V1.0.0.146
you could try downgrading a version and reinstalling using the assistant.
Also factory reset it after reinstalling the firmware. maybe something is corrupt in the firmware or settings
