Numismad
Jun 12, 2023Aspirant
ex7300v2 cannot extend signal from Linksys EA9500V1
Hello everyone! router Linksys EA9500V1 2 wireless 2,4GHz and 5GHz Security mode: WPA2 Personal from: WPA2/WPA Mixed Personal WPA2 Enterprise WPA2/WPA Mixed Enterprise WEP I am tr...
Numismad
Hi Plemans! Thank you for your attention,
Yes I tried to use installation assistant
but nothing, sometimes it's brought me only connection 5GHz
Lynksys don't have WPS button, but I made experiment.
I have another router - D-link Archer AX50 with WPS
and after "Your extender has successfully connected to your existing WiFi network." (look screenshot pls)
its brought ONLY 5GHz connection but 2.4 - not working....
I think probably it's problem with firmware of ex7300v2? (
Any ideas?
Thanks!
Jun 16, 2023Guru - Experienced User
Your photo shows both connected.
What firmware are you on for it?
- NumismadJun 16, 2023Aspirant
Thank you for your answer.
yes it shows like connected but after it is not connected
I try to use any firmware, last one EX7300v2_EX6400v2_EX6250v1_V1.0.0.146
- plemansJun 16, 2023Guru - Experienced User
you could try downgrading a version and reinstalling using the assistant.
Also factory reset it after reinstalling the firmware. maybe something is corrupt in the firmware or settings
- NumismadJun 18, 2023Aspirant
I tried but i think it's bug in firmware and conflict with another manufactories
