fleetmack
Sep 25, 2020Aspirant
EX7300v2 firmware - SLOW
I've had this thing for about 6 months running firmware 1.0.0.124 and it's been bulletproof. It's a wired access point. Never rebooted it and consistently getting about 450down and 600 upload speed. ...
Sep 25, 2020Guru - Experienced User
have you tried factory resetting the primary router and the extender?
Then reinstalling them.
- fleetmackSep 25, 2020Aspirant
Nothing has changed on the router (zyxel). I did reboot it anyways, I get 950down/1020up hardwired to that router (it doesn't have any wifi antennas turned on it). But yes, after i rebooted that, I did a hard reset of the access points. I'm not going to do a hard reset of the router, there is a 0% chance that will fix anything.
