DENIN
Nov 30, 2018Aspirant
EX7500 - Drops internet connection when device is connected
Hello,
I just received and setup the EX7500 range extender in my house. The setup went fine, and my devices (in this case iPhone X and XS Max) initially connected. However after a few minutes...
Apr 07, 2019Guru - Experienced User
What Firmware version is loaded on the EX?
What is the Mfr and model# of the main host router the NG extender is connected too?
What is the distance between the main host router and the EX unit?
What channels are you using on the main host router?
- Carsten_RApr 21, 2019Aspirant
I've the same Issue,
but only with my IPHONE and Sony-TV Devices.
Android, Mac OSX and Windows are working well.
Any solution ?
- Hardware Version: EX7500
- Firmware Version: V1.0.0.52_1.0.68
Main-Router:
ModelNetgear Nighthawk X4S R7800ArchitectureARMv7 Processor rev 0 (v7l)Firmware VersionOpenWrt 18.06.2 r7676-cddd7b4c77 / LuCI openwrt-18.06 branch (git-19.020.41695-6f6641d)Kernel Version4.14.95- FURRYe38Apr 22, 2019Guru - Experienced User
What is the distance between the router and extender? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What wifi modes do you have configured on the main host router?
Try using a manual channel.
Any solution ?
Main-Router:
