CTagg
Nov 27, 2020Aspirant
EX7500 5Ghz connection issues with Virgin Hub3.0
I have a EX7500 that has 5Ghz connection issues with my broadband Virginmedia Hub3.0. The EX7500 is continually problematic and is not a stable product. It is very difficult to set up as the initiatio...
Nov 28, 2020Guru - Experienced User
Which firmware is on the EX7500?
Did you set it up connected to the virgin hub using WPS?
CTagg
Nov 28, 2020Aspirant
The most updated version of the firmware is loaded on the EX7500 and yes set up as WPS.
- plemansNov 28, 2020Guru - Experienced User
CTagg wrote:
The most updated version of the firmware is loaded on the EX7500 and yes set up as WPS.Which version? The most "updated" sometimes isn't, is a bad version, or it changes and if others have this issue, the actual number helps.
don't install it using wps. Virgin hub router implemenation of wps sucks. It creates all kinds of issues.
Factory reset the EX7500 and then install it using the installation assistant and not wps.
- CTaggNov 28, 2020AspirantOk thanks. Just tried installation again from scratch straight after factory reset using installation assistant (which isn’t great either) and the same issue exists. No connection on 5Ghz.
- plemansNov 29, 2020Guru - Experienced User
Firmware on the EX7500?
No connection to 5ghz as in you can't connect a device to the extender or you can't connect the extender to the router?
You need to be specific
