DMPierce
May 21, 2026Aspirant
Ex7500 dropping off about 1-2 times per week
I am having the same problem with my Nighthawk R9000 staying connected. Ex7500 dropping off about 1-2 times per week. Very annoying.
May 22, 2026Guru - Experienced User
A couple things to try.
- Set your R9000 to use non-DFS channels for the 5ghz.
- Re-run setup on the EX7500. DON'T setup the 2.4ghz. It'll still work fine but it won't function as a backhaul. It'll strictly use the 5ghz backhaul.
If for some reason the router's 5ghz isn't stable, the extender will use the 2.4ghz as a backhaul. Which is slow and sensitive to interference. It tends to cause issues if you're in a congested area versus the 5ghz reconnecting.
DMPierce
May 27, 2026Aspirant
I have turned off the 5ghz. I have enabled 2.4ghz for extended devices that don't use 5ghz
- FURRYe38Jun 26, 2026Guru - Experienced User
Does this solve the problem for the EX extender?
