MatchesD
Apr 19, 2020Aspirant
EX7500 Extender - no 36 channel option for 5ghz
My internet router is provider by my carrier and has fixed channels for both the 2.4 and 5 ghz frequencies. The 2.4 is on Channel 1 and the 5 ghz primary is on 36 with the secondary on 157. When I set up my EX7500 for mesh extention (or in API mode) the Nighthawk will ignore the incoming 2.4-1 channel and take in the 5-36, then retransmit this on both the 2.4-1 and 5-157 channels of the Nighthawk (however as such I can only use the 5 ghz channel for internet). If I try to change the 5 ghz channel in the extender the lowest selection offered if 149! As such I cannot select channel 36 in the 5 ghz frequency, and since I cannot change my router channel, this is basically unless.
When I select the Nighthawk to only select the 2.4 for mesh it will do that no problem; so in summary I cannot use my extender eventhough Netgear state that this unit is "universally compatible". Obivouslly not the base as they don't offer lower 5 ghz channel selections.
in the eX7500 the 5ghz chips are designed to run either the low band or the high band. They can't run both. its designed that way.
And its designed to run a dedicated connection between the router and the extender. hence the extender running channel 36 to communicate with the router.
the way extenders are designed is the radio communicating with the router needs to be on the same band. Its why standard extenders channel selection is disabled when running in extender mode.
Not being able to run both 5ghz radios on the same channel is actually a benefit. If you had both wireless 5ghz chips running on channel 36, they'd interfere with each other. Causing interference and slow downs because they can't broadcast at the same time. Versus it being able to recieve/transmist between extender----router at the same time the other 5ghz chip is communicating with devices. It'd ruin the whole point of having a triband extender as only 1 of the 5ghz chips could run at a time.
I'm not sure why you think channels 149+ are useless? Your devices should still connect to them fine.
Mabye some more details on what makes you believe they're useless and what you're attempting to do?
- MatchesDAspirant
Thanks for your comments but I never said that the higher channels were useless; I said that this extender isn't useful to be if I'm only able to use the higher 5ghz channels with it as I cannot change my routers 36 channel. Because of this I can only get either the 2.4 ghz or 5 ghz out of the extender, not both at the same time. And as devices swtich between both based on their useage, some of my devices will not connect to the extender. I'm trying to determine if there's a solution or workaround with the extender or if I'm forced to attempt to get my routers 5 ghz channel changed.
MatchesD wrote:Thanks for your comments but I never said that the higher channels were useless; I said that this extender isn't useful to be if I'm only able to use the higher 5ghz channels with it as I cannot change my routers 36 channel.--- You wouldn't want to or they'll interfere with each other. Because of this I can only get either the 2.4 ghz or 5 ghz out of the extender, not both at the same time. ---yes you can. But devices can't connect to 2.4ghz AND 5ghz at the same time. And as devices swtich between both based on their useage,---bandsteering. some of my devices will not connect to the extender.----which devices? I'm trying to determine if there's a solution or workaround with the extender or if I'm forced to attempt to get my routers 5 ghz channel changed.
It can use both the 5ghz and 2.4ghz at the same time. they're different radios and can broadcast at the same time.
It also has band steering and will switch devices between 2.4ghz and 5ghz if you're using bandsteering.
It also has mesh so it'll use the same ssid as your router and allow the devices to roam based on their roaming standards if you're using it.
I guess i'm still confused as to why think you can't use the higher 5ghz channels?
And what device are you using that you think can't use the higher 5ghz channels?
Are you thinking a single device can connect to 2.4ghz AND 5ghz at the same time? They can't. they connect to 1 band at a time.
