MitchM512
Mar 16, 2021Aspirant
EX7500 Extender won't connect to modem/internet
My EX7500 Nighthawk extender will no longer connect to my modem. My internet is working fine, tested the speeds as well. I have tried several times to do the factory reset. I complete a couple pro...
Mar 17, 2021Guru - Experienced User
What firmware is on the extender?
What router are you trying to connect it to?
MitchM512
Mar 17, 2021Aspirant
Firmware should be whatever the factory setting is. I didn't make any adjustments to the firmware.
Router is a BGW210-700 for AT&T
- plemansMar 17, 2021Guru - Experienced User
MitchM512 wrote:Firmware should be whatever the factory setting is. I didn't make any adjustments to the firmware.
And some firmwares had issues or could have had issues. Its why we ask.
we're members of the public helping out for free. We're not netgear. Please put a little of your time to help us to help you.
Also what are all the led's on the extender doing (color/blinking/solid)
- MitchM512Mar 17, 2021Aspirant
Yes thank you! I appreciate the help.
Firmware is : V1.0.0.72_1.0.78
All the lights are solid blue, but the 2.4 and 5.0 lights are not.
I tested my speed with AT&T and I have 423mbps Download & 394 mbps Upload.
The led's are indicating its connected if the power/router link/wps lights are all solid blue.
the 2.4ghz/5ghz lights are for when a device is connected to the extender.
Why do you think its not connected?
