joebl
Jun 20, 2019Aspirant
EX7500 Extender
While configuring some wifi devices, I notice that I have the 2.4 network at 100% and the 5ghz network at 80%. So which is one is going to give me better performance and reliability.
- Jun 21, 2019
Got it thank you.
Jun 21, 2019Guru - Experienced User
Thats a loaded statement. I'd turn the 5ghz power back up though.
5ghz has higher throughput. That means faster speeds.
2.4ghz has further reach and penetrates better.
So in terms this means that 5ghz is faster but doesn't reach as far and can't go through objects as well. It also has the benefit of more wifi channels. This means less interference from other 5ghz channels broadcasting and because it doesn't transmit as far, less interference because of this.
Here's an acticle with more details.
dancer1945
Jul 08, 2019Aspirant
maybe you can answer my questions too. i got my new extender yesterday and was able to install and setup. i have a R7000 router. after setting up the extender, i went to "setting" on my iphone>Wi-Fi and was able to see and select the extender NEATGEAR-EX. after couple hours, it is no longer available in the setting>Wi-Fi and therefore unable to connect devices to the extender. another question: the extender has all solid blued lights except the 5Ghz. i think my router R7000 has bothe 2.4Ghz and 5Ghz. thanks for your time and patience
- joeblJul 08, 2019Aspirant
I cannot, so if I were you I post a new message. Also, I have had some interaction with tech support and they are pretty good, so that's available to you as well.
