Chuck72kcc's avatar
Oct 01, 2020
EX7500 Firmware Install Hang
I started a firmware install this morning - it ran for over 2 hours and it appears to have hung up as it never finsihed - in fact it never got past 3% completed. I have tried a factory reset several ...
  • Chuck72kcc's avatar
    Chuck72kcc
    Oct 01, 2020
    Short story it is working...
    Long Story - I used your 192.168.1.250 address hint and that got me into the process. This was after I did the 30/30/30 reset. Still didn't get through the process, however I was able to log into the device using the 250 address, but never say saw the "_EXT" wireless network, nor 2.4/5GB lights.
    But having gotten logged in and into the software I found the "Software Reset" icon so I figured "why not" and let that run...that took some time, but after that I got the "_EXT" network and after that I was able to go through the entire setup process.
    Also I ran through just about anything I could and found the Firmware update had indeed happened and Extender was at V1.0.0.68_1.0.76 level - which is the latest it said.
    So in the end with some patience and your help it is functioning...."unbricked". Much thanks!!
