Chuck72kcc
Oct 01, 2020Tutor
EX7500 Firmware Install Hang
I started a firmware install this morning - it ran for over 2 hours and it appears to have hung up as it never finsihed - in fact it never got past 3% completed. I have tried a factory reset several ...
- Oct 01, 2020
Short story it is working...
Long Story - I used your 192.168.1.250 address hint and that got me into the process. This was after I did the 30/30/30 reset. Still didn't get through the process, however I was able to log into the device using the 250 address, but never say saw the "_EXT" wireless network, nor 2.4/5GB lights.
But having gotten logged in and into the software I found the "Software Reset" icon so I figured "why not" and let that run...that took some time, but after that I got the "_EXT" network and after that I was able to go through the entire setup process.
Also I ran through just about anything I could and found the Firmware update had indeed happened and Extender was at V1.0.0.68_1.0.76 level - which is the latest it said.
So in the end with some patience and your help it is functioning...."unbricked". Much thanks!!
Oct 01, 2020Guru - Experienced User
If the extender power light is solid blue, it usually indicates that its on.
Do you have a different device you could try connecting to it?
When you're connected via the wireless signal, can you try going to 192.168.1.250? its the default ip address.
sometimes it'll work when mywifiext . net doesn't.
Chuck72kcc
Oct 01, 2020Tutor
- plemansOct 02, 2020Guru - Experienced UserGlad to hear you got it up and runnin!
