jpd99's avatar
jpd99
Guide
Feb 10, 2022
EX7500 issues keeping 2.4GHz devices connected
EX7500 is connected to R7800 router.  5GHz devices do not have an issue but 2.4GHz devices will connect for a day or 2 and then looses connection.  Once that happens I can not get them reconnected un...
  • plemans's avatar
    Feb 10, 2022
    Not on the R7800.
    Just went you're going through setup of the EX7500. It asks you if you want to extender the 2.4ghz. Deselect that.
    You'll still be able to use the 2.4ghz, it just doesn't use it as a failover if the 5ghz has an issue. Leave the 2.4ghz broadcasting on the R7800.
    You can try changing which channel you're broadcasting on.
