jpd99's avatar
jpd99
Guide
Mar 07, 2022
EX7500 issues not solved
I've been fighting this for over a year now and thought I had it resolved by changing the channel of 2.4GHz.  Over time it still looses connection with devices.  Another problem that is happening (ab...
  • plemans's avatar
    Mar 07, 2022
    when you did your setup, did you click on the "extender 2.4ghz" button?
    If so, go in and re-run setup. Uncheck that box.
    You'll still be able to use 2.4ghz but it won't use it as failover for the 5ghz.
