Rogerwhit's avatar
Rogerwhit
EX7500 Range Extender. I get all blue lights but 2.4 and 5 GB lights don't come on.
The set up seems correct, I get all steady blue lights, but the 2.4 GHz and 5GHz lights will not illuminate.  Logging into the extender  says "Your WiFi extender connection is up and running.  All th...
  • FURRYe38's avatar
    Apr 02, 2019
    Is smart connected enabled on the R9000? Try the EX with the R9000 with SC disabled and see.
    The 7500 may not be a good match for the R9000. The connection rates are slower than what the R9000 supports so the EX will be a bottle next in some regards...
