Rogerwhit
Apr 02, 2019Aspirant
EX7500 Range Extender. I get all blue lights but 2.4 and 5 GB lights don't come on.
The set up seems correct, I get all steady blue lights, but the 2.4 GHz and 5GHz lights will not illuminate. Logging into the extender says "Your WiFi extender connection is up and running. All th...
- Apr 02, 2019
Is smart connected enabled on the R9000? Try the EX with the R9000 with SC disabled and see.
The 7500 may not be a good match for the R9000. The connection rates are slower than what the R9000 supports so the EX will be a bottle next in some regards...
Rogerwhit
Apr 03, 2019Aspirant
Just for grins, I turned off SC on router before running off to my hecktic day. I looked down at the extender an 2.4 and 5 ghz lights were blue. Doesn't it bother you to know so much about this arcane business? Mother nature doesn't like routers and extenders I'm sure.
