JECaine's avatar
JECaine
Tutor
Mar 25, 2021
ex7500 won't connect to my router
Hey all, I'm sure this conversation exists, but I'm too frustrated to go looking all over for this exact issue. Can anyone tell me why this ex7500 won't connect to my 5ghz network.  I've done the wps...
  • plemans's avatar
    Mar 25, 2021
    How far from the router are you?
    Have you tried using the installation assistant and unchecking 'extender 2.4ghz" during setup?
    It still allows you to use the 5ghz but it won't fall back to the 2.4ghz backhaul if there's an issue.
