MJB23211
Jan 13, 2021Aspirant
EX7500 won't reach furthest part of my house!
Hi there, I bought the EX7500 late last year and whilst it works fine I still have a problem where the furthest room away from the router cannot be reached with wi-fi even when using the EX7500. ...
Jan 13, 2021Guru - Experienced User
How big is your home and what material is it made of?
I usually tell people who're needing more than 1 extender, to move to a triband mesh system.
Using multiple extenders can cause network instabliity because nothing is controlling them.
Versus a full mesh like Orbi has the router controlling how they connect to the router and to other satellites.
the main difference from the EX7500 to the EX8000 is the wireless backhaul that each has. The EX8000 has a wider (faster) backhaul but its fronthaul is the same 866mbps.
You can try going with a 2nd extender to see if it helps.
Another option is the RBS40V. It has an extender mode. And that way if it does have the instabilities I warned about, you could still use it for an Orbi system as it has both modes. Plus it has a speaker and tends to be cheaper than the EX7500/8000
- MJB23211Jan 13, 2021Aspirant
Thanks for the reply.
House is about 3,000 sqm and made of Cotswold stone so very thick in places!
Isn't the EX7500 a tri-band mesh system already though?
I can't use Orbi as the internet provider we are with supply their own router and I can't change away from that sadly.
Do you think that replacing the EX7500 with the 8000 may reach that dead spot?
plemans wrote:How big is your home and what material is it made of?
- plemansJan 13, 2021Guru - Experienced User
MJB23211 wrote:Thanks for the reply.
House is about 3,000 sqm and made of Cotswold stone so very thick in places!----ouch. This is going to do a great job of blocking wifi.
Isn't the EX7500 a tri-band mesh system already though?----It is a triband extender. but it doesn't have anything controlling the system like the orbi systems do. so when using triband extenders, if you're using more than 1, tend to be less stable then a full mesh system.
I can't use Orbi as the internet provider we are with supply their own router and I can't change away from that sadly.----Orbi has access point mode. This leaves the ISP supplied device running the routing with still being able to use orbi's wifi/ethernet setup.
Do you think that replacing the EX7500 with the 8000 may reach that dead spot?----Maybe? The ex8000 isn't going to broadcast further its just going to have more potential backhaul speed when you do connect.
OK - so what would you recommend as the best solution then - Orbi with an extender? If so, which one?
