ppines
Apr 26, 2020Aspirant
EX7700 — AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender not connected to a WiFi-enabled computer
I purchased the EX7700 — AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender a few days ago and followed the Quick Start guide. After the software installed the Netgear listed on my internet access list ...
Apr 26, 2020Guru - Experienced User
What router is it connected to?
What method of install did you follow? wps or the installation wizard?
If it was wps, I'd recommend re-running it using the installation wizard.
What firmware is it on?
ppines
May 03, 2020Aspirant
It's not connected to a router. I am using wifi. Initially, I downloaded the app, used "New System Setup", selected Nighthawk and scanned the QR code - it said the code wasn't valid. So I went online. I have since managed to get all 3 LED lights back, however, it's not listing. I checked the wifi network properties and it's not there either.
- plemansMay 04, 2020Guru - Experienced User
ppines wrote:It's not connected to a router. I am using wifi. Initially, I downloaded the app, used "New System Setup", selected Nighthawk and scanned the QR code - it said the code wasn't valid. So I went online. I have since managed to get all 3 LED lights back, however, it's not listing. I checked the wifi network properties and it's not there either.
None of what you put helped.
It needs a router to connect to. So what router are you using?
You didn't put what firmware you're on.
you put "all 3 led's back" but there's 4 leds. And you didn't list color/solid/blinking. be specific. I'll link to the support site that has the manual that walks you through what each led means.
You put you couldn't use the app so you "went online" and did what? went to routerlogin? searched for help? What did you do?
- ppinesMay 04, 2020Aspirant
I am using a ZTE MF920V 4G portable WIFI modem, I don't have a router. I didn't put what firmware it's using because I don't know. How do I check? The first 3 LED's are solid white, as I don't have ethernet the last one's not lit. Does that matter?
Here's how I set it up using WPS: https://nighthawksetp.com/netgear-nighthawk-ex7700-setup/
It's now listing in my wifi settings, however, there doesn't seem to be any change in my wifi speed. What else do I need to do?
- plemansMay 05, 2020Guru - Experienced User
What change are you expecting to see? The ZTE MF920V is a single band wireless N devices.
And is it working?
Did you retry running setup using the installation wizard and not wps?
