ppines
Apr 26, 2020Aspirant
EX7700 — AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender not connected to a WiFi-enabled computer
I purchased the EX7700 — AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender a few days ago and followed the Quick Start guide. After the software installed the Netgear listed on my internet access list ...
ppines
May 04, 2020Aspirant
I am using a ZTE MF920V 4G portable WIFI modem, I don't have a router. I didn't put what firmware it's using because I don't know. How do I check? The first 3 LED's are solid white, as I don't have ethernet the last one's not lit. Does that matter?
Here's how I set it up using WPS: https://nighthawksetp.com/netgear-nighthawk-ex7700-setup/
It's now listing in my wifi settings, however, there doesn't seem to be any change in my wifi speed. What else do I need to do?
May 05, 2020Guru - Experienced User
What change are you expecting to see? The ZTE MF920V is a single band wireless N devices.
And is it working?
Did you retry running setup using the installation wizard and not wps?
- ppinesMay 11, 2020Aspirant
Yes, the ZTE MF920V is working, but I am getting really poor wifi, PING = 110 ms, Down = 0.88 Mbps, Up = 1.10 Mbps. I thought I could use the nighthawk as an extender and improve the speed. Is that not possible? I have retried running setup using the installation wizard and not wps multiple times, but it didn't seem to make a difference. That's why I switch to wps. Am I waiting my time and money?
Looks like my ISP is restricting my speed, nothing wrong with the setup. See attached.
- plemansMay 11, 2020Guru - Experienced User
Those are the speeds directly off the router?
The router is the backbone of the whole system.
If its slow, everything else is going to be too.
