MattDJUK
May 10, 2020Aspirant
EX7700 - Using 3 of them - but struggling to get them as "one network"
Hi all, Bit of newb when it comes to this. So a step by step dummies guide would be great :D I have 3 x EX7700's, all connected by CAT7 direct from a Virgin Media router. After some pain, ...
- May 10, 2020
Yes you can run orbi with ethernet backhaul and wireless.
It also has outdoor rated extenders as well.
I've ran orbi for years and loved it.
MattDJUK
Hi Plemans,
Thank you for the response.
Does the Orbi system allow for each transmitter to be CAT7 wired? I.e. it doesn't rely on wifi to transmit more (or weaker) wifi?! (If that makes sense)...
Does this fit my requirements?
May 10, 2020Guru - Experienced User
