cedru
May 20, 2021Initiate
EX7700 / Loss of configuration on reboot ( soft or hard)
I think that since the last update, the wifi point no longer saves the configuration which is lost on reboot ( soft or hard ) Hardware Version: EX7700 Firmware Version: V1.0.0.216 Br,
AJBI
May 25, 2021Aspirant
I have just had exactly the same issue - moved router and had to set up from scratch. It always used to remember settings so I can only assume it is the new firmware. Thought I had missed a step out so powered off again,and it reset and had to set up again. Not ideal!
Ngportal
Jul 22, 2021Aspirant
Hi.. Has anyone got a successful fix please? I have gone down 3 levels of firmware to no avail... Help!
- cedruJul 22, 2021InitiateI bought a new model from a competitor. I spent time with support on the phone without success. On some Netgear series, had reliability issues with flash memory.
- CudmanJan 09, 2022Tutor
Exactly the same problem. Very happy to announce that the unwillingness of Netgear to acknowledge this as a problem has lost them a faithful customer. Been using their products for ages. No more. With the new Synology router launching in 2022 there will be no more Netgear. Ever. Poor design as evidenced here. Limited functionality as in locked down access to router internals.
- olympos1625Jan 13, 2022NETGEAR Employee Retired
Hi Everyone,
Good day!
We are sorry for the inconvenience this has caused you, We would like to endorse you to NETGEAR Level 2 support team for callback. Please provide the following information:
Name:
Email:
Phone:
Preferred schedule (atleast 2 days ahead)
Timezone:
Device S/N:
Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
I am looking forward to your response.
Oliver
Community Team
- romfr989Feb 06, 2022Initiate
Hi there,
I experienced the same issue when upgrading to firmware 1.0.0.222.
When reverting back to 1.0.0.174, the extender does not reset after a reboot.
However, the issue re-appears when upgrading to 206, 216 or 222.
174 seems to do the trick.
I have yet to try to upgrade to 188 or 202 (210 seems to have other bugs, so I won't try it).
By the way, not sure what's the difference between 202 and 206, the release notes are identical...
Please note that before downgrading or upgrading firmware, I reset the extender (using the reset button on the back).
Hope this helps
R
- romfr989Jun 06, 2022Initiate
Hi there,
Quick update on this.
I have managed to fix the reset issues through the following procedure:
Reset the extender (through the button on the back)
Reverted back to the first firmware released (1.0.0.148)
Reset the extender again (through the button on the back)
Upgraded the extender to the latest release (1.0.0.226 at the time)
Reconfigured the extender
Since then, I don't have any reset issues, but the extender becomes unstable after 15 days (connections drop, can't do video calls without any disconnection). After a double reset and reloading the configuration, it works again for another 15 days.
R
