newnighthawkX6
Sep 01, 2020Aspirant
EX7700-100AUS display lights
When turned on we get3 whit lights then after a while the Router Link light goes pink. Is this an issue we should be concerned about.
Thanks
You can look up what each light means in the manual.
you can find it here: https://www.netgear.com/support/product/EX7700.aspxare you having issues?
- newnighthawkX6Aspirant
have reviewed the comments thank you. Have found that if the extender is turned off then on again after a while then all lights are white but have noticed that if the home computer is turned on, which is connected to the modem via ethernet cable, then the extender connection to modem light goes pink again. Any suggestions thank you.
