Droider
Feb 22, 2024Guide
EX7700 5GHz Channel Selection
I live in a multi-unit apartment building, and I'm using an EX7700 extender with an R7800 router. I've split the channels, and the router is broadcasting the 5 GHz band on channel 153. I would like...
Droider
Feb 23, 2024Guide
Very helpful. Thank you.
So I understand why I can't use channel 153 for a front-haul channel, but why aren't any of the other upper-register 5GHz channels available for the fronthaul?
Feb 23, 2024Guru - Experienced User
because its a hardware difference. The radios either work for the upper 5ghz channels or the lower ones because of channel overlap.
So if you're using the upper channels for the backhaul, you have to use the lower for the fronthaul.
