Aly_B
Apr 18, 2020Aspirant
EX7700 AC2200 Nighthawk X6 Tri-Band Wifi Mesh Extender doesn't show an extender network during setup
The router is Virgin Media. The extender was plugged into the mains directly next to the router. Unfortunately, my mother tried to set it up so I'm not entirely sure how the original setup went. ...
Aly_B
Apr 24, 2020Aspirant
Not really but we did get it to work. I unplugged the router and let it start back up again. Reset the extender a bunch if times and held down the pair button on the router for much longer than needed. After a couple of repeats it worked.
I think it's mostly down to luck and patience. Hope you can get yours to work.
